This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Plates and thin sections
Would it be possible to provide better analysis of plates and thin sections.
I do lots of work with steel plate and it sure would be great to get good stress
results that were dependable without having to use a huge number of elements.
Again since I work lots with steel plate non-linear bucking analysis would be very helpful.
3 Comments
vex
I think what you're desiring are thin elements to represent thin component parts (IE 2D elements with modified stiffness matrix to emulate the plate thickness). This way you could have a single element to substitute an entire panel, on say a large vessel (boat), so rather than having an extreneous number of elements you have a couple hundred. The caveat is, however, that the deformations and internal panel stresses at local foci won't be available unless you increase the element count to capture it. In some instances this isn't so much a problem as the increase in computational power far outways the necessity for accuracy in the element.
Such a desire shouldn't pose any problem for AD as they already have such elements in the Inventor Profressional Suite.
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
