Hello
Currently once the move/copy command is completed the values seem to reset.
If you edit this the move/copy command in the timeline, all the values are 0.
Would be amazing if Fusion could remember the input values from the initial command.
Also number of copies would make this command perfect. I realise pattern can achieve some results, but as a staircase draftsman, spiral staircases are currently a pain in fusion due to the orientation not delivering.
The only solution I have found is a tedious copy paste for each tread, and hope things don't change!
Max has a great plugin called clone with this functionality
