Show only
Search instead for
It would be useful to have the ternary operator "(condition)?true:false" to address those occasional parametric needs that can't be easily kludged with nested min/max functions.
It is kludgy, but one can do a closer approximation of this function than nested min/max using the sign() function. One must arrange the test to return a positive or negative value. Then multiply one expression by sign(test) and another by sign(-test) and add them together. One sign() will be 0 and the other 1. One of the two expressions will be adding 0 and the other 1 x the desired expression.
However, it would much clearer and not so kludgy if there was a Ternary operator.
