Multi profile selection in edit feature
This may just be a bug but when I create a new extrusion, I am able to select as may profiles as i want. however, after it is created, if i select edit feature (on the original extrusion) i can only modify the selection profile by a single profile. if for instance i need to add 2 profiles to my selection, i have to edit feature, select one of them, hit enter, then select edit feature again, and select the other profile i would like to add. this gets very annoying when i want to add 5+ Profiles to the selection.
3 Comments
HughesTooling
You will find similar behavior with some other features as well Fillet for example. The trick to adding to the selection is to hold the Ctrl or Command key down this suppresses the feature and allows you to make more selections, entering zero for the size of the feature has the same effect.
Holding the Ctrl key down to add to selections is pretty standard in Windows apps, don't know about on macs.
Mark
keqingsong
Thank you for posting your idea! The idea is now 2 years old and does not have many votes, so we are going to archive it. If this is still important to you, please make a new post with the idea included. You can follow the idea submission guidelines here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
