Show only
Search instead for
every time i use mcMaster-carr i need to resize that window. can you store that size in your fusion360 config. i use a 4k display and it shows 15x9cm very small, see image. thanks
I recommend going to mcMaster-carr's website on a normal browser and the after finding the product code just paste into search bar in Fusion's mcMaster window. The window is a bit small but this workaround helps quite a bit.
