This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Joint Origin creation interface: super-easy change reduces burden to user
The Joint Origin dialog box provides the capacity to select the Type of Origin- "Simple" or "Between two faces"; making the second selection presently requires clicking on the Type pull-down menu, drawing down until "Between" is selected, then clicking.   Not such a big deal if performing this operation only once- but when confronted by a large number of components, the process is onerous.
This selection may be accomplished with greater ease by replacing the pull-down menu with simple two-state radial buttons- one click between the two choices, no drawing, aiming, or additional clicks required.   Those required to frequently use the interface will appreciate the change.
1 Comment
Scoox
I think the reason this idea didn't get votes is because the pull-down menu is consistently used in other parts of Fusion 360 for selecting types.
While a drop-down for a 2-item list does seem overkill, it probably was used to make the UI future-proof: should new joint origin types need to be added, they can easily be added to the list without any modification to the UI.
