I'm modelling a detector and currently looking at the most optimum position to place a sample in a X-ray beam but looking at the point of maximum volume intersection between two bodies in Fusion360. This is achievable using the Interference tool found in Inspect. Since I am testing a testing a large number of positions I thought that instead of moving the object each time and repeating the Interference combine calculation it would be easier to use the API to do this repetitive procedure.
However I have found out that the API doesn't currently support any of the Inspect section of Fusion360. Could the developers look into introducing this feature.
