today I played with the section analysis and found out one problem.
If two bodies are positioned side by side and you do a section analysis you cannot distinguish the two bodies anymore.
(see image below)
The cut surfaces are presented using the same material, even if both bodies have a different material.
It would be great if the cut surface shows different materials as well.
Further more there is no edge visible between the two bodies so it looks like it is one body weld together.
Another feature I would like to have is to create one single section analysis for each body / component.
So the cut surface you can set for each body on a different position.
Thanks!
