Drawings seriously needs:
1. basic DXF export
2. Usable PDF export with clean path and not that path salad Fusion Drawing/Autocad creates
3. Maybe a DWG without the view links jusy an old and basic DWG that is more compatible
Because:
DWG - Uses the Autocad drawing views hardly any other software I tested uses (incl. Rhino and Alias)
PDF - The path the PDF exporter creates are utterly nonsense and chaotic so you cannot use it for technical illustration or saving from AI as DXF or DWG
So both option already have some major issues, the DWG locks you into Autocad and the PDF export you can use for handouts and thats it.
If a place does not use Autocad you can throw the Fusion DWG into the trash can. If you are on windows you could try and download 470MB for DWV Viewer which unpacks into 1.2 GB to view and edit DWGs (seriously?) but this is only Win not Mac.
Currently I would have to export all the models as step and then do the drawings in a different application where I can get either
the CNC lines I need (uses line and arc representation) or the NURBS to Bezier spline export I can use for technical illustration in Illustrator.
