There is a need to import curves from a step file and then to edit them. It is necessary to construct the model geometry in Fusion 360.
Why when you create a new file from step, Fusion 360 does not import the curves of the wires that are in the step file?
Why the extracted curves taken by the instrument "Include 3V geometry" can not be edit, where CV points how to modify the curve?
Add the ability to edit and modify a curve by points, otherwise it is impossible to work normally.
