The level of frustration for a newbie installing Fusion 360 is greatly dependent on the software setup relative to his hardware. Before you do anything, you need a tool that will help you check compatibility and configure the software to work with your hardware. In my case, I had a mouse that should have been compatible but wasn't and a graphics configuration that was interfering with selecting planes and objects in Fusion 360. At tool that could help sort that out will make for happier newbies.
