This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Group Objects for Project to Sketch Operation
I recently wrote a blog on using Fusion 360 to help with complex part placement in an ECAD tool.
http://circuitmaker.com/blog/Blogs/guiding-funky-part-placement
About 3/4 of the way through the blog,  see this:
"The idea here is to project the top of the bodies to a reference plane to get sketches of all the placement guides. Here is the only down side - Fusion 360 requires you to click on each body separately to group the projection operation. There is no way to select them all. It only takes a minute or two though! And think of all the time you’ve saved otherwise!"
If I have a large group of bodies that I want to use in projection operation, I have to click on them one at a time.  for large patterns this is time consuming.   It would be great if I would select everything in the tree menu on the left to save lots of clicks
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
