Give geometry in sketches a color for2D laser cutting CNC cutting
It would be great to have to possibility to give diffent geometry within a sketch a difrent colour.
If the sketch is exported, every colour is on a diffrent layer, named to the colour and displaeyed as that colour.
This is ideal for laser cutting, every colour could be used for a difrent power setting.
And for future editing in Autocad, as you easaly can switch off the layers.
1 Comment
promm
Status changed to: RUG-jp審査通過
Thank you for your idea, this is getting archived due to the solution that we have for sending a design laser cutting.  In our CAM environment you can create the coed to do the cutting on your machine.  Using colors to aid in the workflow for creating laser, water-jet cutting is something that I have explored and we may look into at a later point in time.
Mike Prom
