The CAM Feature would be a totally one stop feature if it had a feeds and speeds calculator. Currently I use GWizard from CNCCookbook. You can enter in the depth of cut, tool engagement, material, tool information, and how aggressive you want to be in the material removal and it will calculate a feedrate and spindle speed for your cut. I have found that the GWizard feeds and speeds calculator is very accurate and keeps me from burning up or breaking my tools. The calculations are not complex and one could easily integrate a feeds and speeds calculator into the CAM within Fusion 360 that could automatically set (with manual override of course) what the feed rate and spindle speed should be.
Having this feature within the CAM would make Fusion 360 CAM a killer program. I wouldn't need to use any other program to get to gcode from a part drawing.
