DXFs that I export directly out of Fusion won't work with the laser cutter and CNC plasma cutter I use; both can only read older DXF formats such as R14. This means I have to import the files into another program such as DraftSight and re-export them in the correct DXF version. Could there be an option in the export dialog to choose the DXF version? Even better, a user setting that would allow you to specify the default DXF version for exporting so that one wouldn't have to change it every time.
Thanks!
