I just noticed that when I make a change in a DWG - which in this case is a set ot 2 drawings, if I make a change to one drawing there is an asterisk in its tab indicating that the drawing needs to be saved to keep the change. When I click over to the other drawing of the pair, there is also an asterisk indicating that the drawing has had change - which it did not - but wants to be saved. If I only made changes to drawing 2, why would drawing 1 need saving? This brings me to my point; if I have 92 drawings open and I make a change to 1 of those, I would be forced to individually save each of these in thier own window. This is a problem Fusion Team...
My idea is that there should be an option to simply save the one and not be forced to save the others.
