Show only
Search instead for
Thought I had done this before; copy and paste text from one drawing to another. Copy standard notes for example, and no I am not interested in managing templates with notes! Recently encountered wasting way too much time again trying to do something that used to work, with Fusion 360. Current edition (2.0.3803) does not appear to support this?? Talked with others that use more often and had shocked looks that I had ever been able to do this in the first place! Long since resigned to typing... Support with COPY and PASTE selections on wheel would be useful. Similar as Copy & PASTE to/from Clipboard in AutoCAD. Thanks in advance.
@keqingsong - Copying the contents is not the same. Would be great to copy with all the formatting and then double-click to change some text (if necessary).
Since nearly all the other elements are dependent on drawing elements, copying/pasting them doesn't make much sense (would need to re-link the elements). But text is different: sometimes a standard note is duplicated in multiple places. Or you want to maintain consistent formatting: "Notes" section in drawings, etc.
Yes, Keqing Song is correct. The text inside the box can be copied/pasted. I tend to make a NotePad file with the standard text used across multiple drawings to provide consistency.
1) However, it would be a great feature to copy/pasted the entire text box and then control it location/alignment.
2) It would also be handy, if the last font size used would be retained with adding more text. At the moment it uses the default.
Both of these functions would save a great deal of time and provide a more consistent final drawing.
