Please consider adding a drag knife to the tool library and adding tool paths specific to using a drag knife.
Please include
- tool axis offset (distance the tip of the knife is offset from the axis of the spindle)
- a definable angle between two vectors that should be considered a corner
- a setting to partially retract the blade tip to allow the knife to pivot/swivel at a corner before plunging back to the full depth of the material
- feed rate
- multiple passes for thicker materials
It should that the ability to define cuts of A/B parts of an inlay without using a loop move so that there is no material waste.
Also please see suggestions HERE
Thank you!!
