In Short: I would like to add custom data to my component/assemblies and I would like to be able to export that data at a later time. See image below.
Hello everyone,
When I work on designs I go through lots of a component's data; from its measurement and materials to prices, suppliers, order codes and data sheets. When a design is finished I have to gather lots of data before I can start ordering, sharing my design or plan on alternatives. Yes, I could absolutely do all that with a excel sheet but wouldn't it be much easier if we could gather all this information in Fusion and retrieve the right data when we need it?
I'm proposing to update Fusion with the option to add custom data to our components and assemblies. If the data is added and after we've finished our designs we should be able to extract the required data. The method of extraction could be as simple as making a Bill of Materials on our drawings or to extracting a sheet with all order codes, prices and quantities of an assembly. Maybe we could even link data sheets which will then be uploaded to the A360 drive so they will be available everywhere we work.
Alright, that's the major idea. Of course this could be achieved in many ways but I have to following in mind: I feel like we should be able to just add new fields to the properties menu of items. These could then be available for all assemblies and components. Or, possibly, separate the custom properties for assemblies, components and linked-components.
The user created extra properties fields for his components, the data can be extracted to, for example, an datasheet.
Note: See more details in the comments section
The above just comes back to the same example for creating a price list. But when we can create our own data forms and extract just the data we need at the right time, we will be able to use this for many different applications: What about a way to link certain software you've written for your design? Or maybe just add the material class you want to use? (And project that on your BOM) What about simply adding notes and calculations? And will you need to order additional milling bits to create this component, reference those as well!
Again, there are many solutions and I just wrote down one example. The major idea is that I would like to add custom data to my files and would like to be able to extract that data.
Please let me know what you think and feel free to add any suggestion!
