Conditional Parameters: If Then Else
The more we use parameters to drive our design work in F360, the more we wish for conditional logic. There aren't many workarounds to having conditional statements in parameters.
I'd love to be able to set parameters like:
HoleWidth= 24 in
Width = 60 in
MinHoles = 2
HoleCount = if(Width / HoleWidth <2 then 2 else Width / HoleWidth)
Another desire with rectangular patterns:
We define the length, width, hole size, and spacing for a pattern of holes in a flat 2D design. We can quickly change the length and width and keep those patterned holes centered, BUT we can't have the
Won't accept a unit based referenceWon't accept a unit based reference
pattern fill the space as it changes size. We have to change the actual quantity of the X and Y repetition in the pattern because the parameter system won't allow a unit-based reference to calculate in a No Unit field.
Confounding this, you can't use a parameter that has a unit in the Quantity field of a Pattern. 🤦‍:male_sign: This seems like an easy fix - just allow that parameter in the quantity field and forget that it has units.
holeCount has unitsholeCount has units
Conditional logic is fairly elementary in scripting and would be a huge boon to the capabilities for parametric design software like Fusion 360.
Inventor and Revit have If Then Else, can we port that over, pretty please?
2 Comments
morrijr
I like the idea (and I've voted for it), but there's a math 'trick' you might be able to use to help you.
can be written as
Math.max(Width / HoleWidth, 2)
What this is doing is effectively clipping the lower bound to 2.
You can also use Math.min in the opposite case where you want to clip the upper bound.
Hope that helps! Can't do anything about the No Units issue apart from perhaps creating a No Unit as your number and another parameter which is equal to the No Unit with a unit. Hum. Perhaps an example might help.
Length = 200
Length_mm = $Length mm
Thoughts?
jbrewlet
@morrijr - thanks for the suggestion. This is a nice way to do some form of conditional work.
