Here is something that should be almost trivial to implement that would be VERY helpful when importing designs:
Add the ability to change line types in sketches. In particular, add the ability to change a projected line to a normal sketch line. When importing models, I often want to create a fully parametric model from an imported solid. I do this by creating one or more sketches to define the features using projected lines. I then delete the solid, overlay the projected lines with normal lines, delete the projected lines, then re-construct the solid features using the new sketch. This works fine, but is rather laborious, the worst part being the tedious "conversion" of projected lines to normal lines. If I could simply select the projected lines, and convert them to normal lines, the process would be quick, easy and painless. I have to believe this would be a truly trivial thing to implement.
Ray L.
