Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Center of Gravity
Center of Gravity
It would be great if Fusion 360 could output the model's COG.
12 Comments
Moments of inertia already got > 10 votes and a BS Ā«implementedĀ» or Ā«solution providedĀ» but +10 / no-brainer on this (and higher moments)
colin.smith
Status changed to: ć‚Ŗćƒ¼ćƒˆćƒ‡ć‚¹ć‚ÆåÆ©ęŸ»č½éø
This feature will be in the second May release.
Colin
Awesome @colin.smith !
Have a project coming up soon that will need that (and the higher order moments šŸ™‚
RobbGodshaw
Lets be sure to make it a selectable point entity, not a frutratingly unclickable dot like it is in Inventor. šŸ™‚
If it's a point entity, make it an origin with the axes defined by eigenvectors of the next moments of inertia (defaulting to the nearest possible approximation of the global ones when they're degenerate)
 Great, not I can finally use Fusion for design šŸ™‚
But @Anonymous it's so much fun trying to do computer aided mechanical engineering with paper and pencil or a whiteboard !
kdeuler
Just reading this idea. COG is interesting. I suppose the default would be that all bodies are made of materials of the same density?!
Yes @kdeuler but you can pick the default material and there is an extensive library (and I think you can already specify custom ones)
In addition, one should be able to specify wall thickness and infill %, to simulate what a 3d printer would do.
keqingsong
Thanks @keqingsong
This looks very cool.. I hope there's also a visual representation (CM and vectors for principal axes that can be used to define an origin : )
