This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
CAM bug select axis on round objects
When you have a round object in CAM and you want to select axis for example setting the Z axis if you click on the cylinder as a refrence the z axis should align axially with the cylinder. Instead it goes like perpindicular or something screwy making it impossible to set axes on objects that don't have straight edges. Instead I need to create sketches to represent my machining axes. This is very inconvenient and if the axes don't line up with global it can be a huge pain in the ****.
2 Comments
jeff.walters
Sorry I didnt reply here as well yesterday. I replyied the below in the Computer Aided Machining (CAM) area
The best place to ask for help is in the Computer Aided Machining (CAM) area or camforum.autodesk.com or email cam.support@autodesk.com
I have submitted this issue on ticket CAM-2024. In the meantime a somewhat simple work around is to create an axis using the cylinder and select that.
brianrepp
Status changed to: RUG-jp審査通過
Archived as this was submitted as a bug
