This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Add 'Selectable All Components' option to top-level context menu
Fusion Team,
As of the Feb 17 release, using the top-level context menu you can restore the visibility of all components with "Show All Components".
However, there is no option to make all components Selectable. You must select each component in the browser and then toggle the selectable status. Correct?
I believe a "Selectable All Components" context menu option at the top-level would be useful.
Whether this extends to components, linked components, bodies, and sketches would be up to the community to decide.
Thank you for your consideration and I welcome your vote.
Jerry
1 Comment
subversivespeed
https://forums.autodesk.com/t5/fusion-360-ideastation/can-we-please-get-selectable-unselectable-away...
 WE need this... As far as I can tell, unless they fix the top component level to indicate when a body within a component is unselectable, this is the next best thing...  As far as I see it, this is not an IDEA its a BUG so I put it into support forum. From what I can tell it was simply an oversight.
