This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
add "remove not wanted" option to solid split command
in timeline when you split you end up with many unwanted left overs.
this makes the browser hard to use and you scroll a lot.
6 Comments
schneik-adsk
Status changed to: オートデスク審査落選
schneik-adsk
We just talked about this internal ourselves. We were thinkin we could add a cut option and then set the side to cut. IT would remove any geometry on the cut side. Sound right for what you are looking for?
cekuhnen
In Alias for example or rhino you can select trim results and the day keep our remove. The same functionality would be great with solid. Rhino offers that option. With complex designs you really do not want your browser to overflow. Our dump them automatically into a collection folder.
haughec
I've logged FUS-14074.
haughec
Changing to Future consideration in lieu of other priorities.
Charles
haughec
