Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Add option to show all sketches when autodesk autohides them!!!
fusion360 often hides all sketches at a local level and you have to open the sketch tab and recheck every single sketch!!! pls add a feature to show all when you right click the sketch tab!!! see attached img.
2 Comments
HughesTooling
Don't know if you know this but you can make multiple selections. Select the top sketch then hold the shift key and select the bottom sketch then right click Show\Hide. Only going to help if you have a lot of sketches though!
Mark
Still a pain to select all when there are a couple pages of them
