Show only
Search instead for
Submitted byAnonymouson05-16-201605:04 PM
Status:
Gathering Support
Add option to show all sketches when autodesk autohides them!!!
fusion360 often hides all sketches at a local level and you have to open the sketch tab and recheck every single sketch!!! pls add a feature to show all when you right click the sketch tab!!! see attached img.
Don't know if you know this but you can make multiple selections. Select the top sketch then hold the shift key and select the bottom sketch then right click Show\Hide. Only going to help if you have a lot of sketches though!
