This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Ability to show parameter names in the sketch view
If I have based a dimension off of a parameter, in addition to seeing the final value displayed in the UI, I would also like an option to see the parameter name.  This way I can quickly scan my sketch dimensions to make sure the parameters are all correct, as well as see the parameter names as a reference when adding/using them in other dimensions in the sketch. (Currently, you have to open up the parameters window, remember the name, then close it again since it's modal to the design.)
4 Comments
think I would be happy with just this:  In the sketch view a dimension would show it's value but would also have some kind indicator telling that it is defined by a parameter instead of just a directly input value.  It seems to me that showing both the value and the parameter name could get pretty messy.  But I could be wrong.  It would certainly be nice to be able to easily double check that all the appropriate parts are set to the correct parameter.  Perhaps it should be a toggling behavior.  You can set it to globally show actual values or parameter names.
I too am looking for similar display. Is there a toggle somewhere?
colin.smith
This item has been archived due to a lack of votes. If you feel this item is important feel free to create a new idea station item.
colin.smith
Status changed to: RUG-jp審査通過
