This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Ability to mirror planes
Requesting the ability to mirror construction geometry to achieve the same angle and distance from a given object when adding features to an existing model. For example, I am redesigning a piece from our design for production, due to constraints on a battery module, there needed to be an angled door with a rail system to slide this battery pack into place, while also having the consumer able to remove the battery pack for charging purposes. I want to mirror the plane I had created earlier in the design used to create this door to the opposing side of the design in order to create a panel for an LED control module while still maintaining a primarily symmetric design. I can still achieve this, however, there are many more steps I need to go through due to the lack of this feature. Thank you for your consideration and I hope this information is useful in the improvement of this amazing program! Big fan of Fusion360!
1 Comment
Are you referring to mirroring sketch construction line geometry or are you referring to mirroring construction planes, axis, and/or points?
I think either way it would be nice to have an 'align' feature for the construction planes so that a person could snap the plane to certain position without manually manipulating it into place using the eyeballing method in collaboration with the right viewing angle or without entering in a coordinate distance in order to locate the plane where it is required.
