6 tool library ideas that I feel are important
These changes would drastically simplify the organization of my library.
1:
The ability to set different speeds/feeds for different materials. Perhaps a dropdown menu.
2:
Add a checkmark field/option to account for chip thinning in the operation's tool/passes tab.
3:
Expand options for tool material/coating in Cutter field.
4:
Add the ability to change the order of tool libraries, right now they are only alphabetical.
5:
Be able to add folders within folders.
6:
Add another IPT field for full slotting.
For example: Niagara cutting tools usually provides different IPT recommendations depending on whether full slotting or using a small stepover.
1 Comment
Captain-DJ
7. A field so set an offset. So i can define roughing tools and the offset (if it set) will automatically used in the operation. So never forget to set it.
8. If an operation is locked, don´t change the speed and feed if i edit the tool speed and feed from the tools menu
