T-S Self Intersection warning a little too extreme! ?
cekuhnen
cekuhnen
This is not really a manifold sub-d surface. the only thing is that one end of the handle flows and cuts through the bottle body but is otherwise not connected in anyway to the mesh.
thus I find the error warning rather odd and problematic because this would mean that you cannot use sub-d in a way well you can use sub-d without TS.
Any insight? A way to not make Fusion refuse this?
undefined
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Replies (13)
PhilProcarioJr
@cekuhnen
Separate in the middle of the handle shown in the picture, when you convert the object you can stitch them back together.
undefined
Ideally in a case like this Fusion should convert the T-Spline into a surface so you can deal with the intersection after conversion. There are also many other ways this could be dealt with to but anything would be better then failing the conversion. It just doesn't make much sense. The software could also do an automatic trim between the offending surfaces which would also be great.
Phil Procario Jr.
Owner, Laser & CNC Creations
cekuhnen
The self intersecting idea is ok and useful to prevent well bad self intersections
but in this case there should be an overwrite button to still produce the nurbs patches
in patch mode I could easily extract the faces trim them accordingly and then stitch everything back together
Claas Kuhnen
TrippyLighting
If it is not already in the Idea station , please put it there and link it back here.
I remember another thread with a very similar topic. I am sure we can gather a few more votes. Here is one  @michallach81
jeff_strater
Why not just use Bridge to join the handle to the body?  That's how I've seen it done in the past.  Then, you wouldn't have the self-intersection.
Jeff
Jeff Strater
Engineering Director
TrippyLighting
The keyword here I believe would be topology.
Try to merge two different diameter cylinders with different numbers of cylindrical segments.
The end result will not look nearly as clean as you'd get with combining two solid cylinders of different diameters.
cekuhnen
@jeff_strater That only works if the topology allows it.
Proper slim topology focused on maximizing detail match with the least amount of CVs is really king in that discipline
when you want smooth transitional surfaces and not some wobble sub-d model.
In the situation with the handle the CV count does not match anything at the bottle surface
You can see that the cap was possible to be included easily though.
You suggestion in this case is not practical and actually bad practice because it would needlessly overcomplicate the mesh.
"a 3 point curve is easier to manipulate and maintain a smooth curve then having 7 points to deal with"
Claas Kuhnen
Phil.E
Sounds like some great new suggestions for Idea Station.
I manually tried the suggestions presented here and had no problem performing the workflow in Patch space. So at least for now you can complete the workflow. Here is what I did:
While it's a T-Spline, make it not intersect. That solves the intersect problem.
undefined
After it's converted to a Patch body, split the handle.
undefined
After the handle is split, extend it into the bottle, trim out the bits you don't want, and stitch it all together again.
undefined
Shell it and you are done.
undefined
The thumb abides.
undefined
Found a few things you might notice, so I'm logging bugs on this:
1. Split body seems to extend the cutting plane really far without checking "extend".
2. Cannot intersect the Patch body across itself, which doesn't seem right, hence the need for splitting the handle.
3. Logged improvement to convert T-Splines like this into Patch bodies if possible, linked to Idea Station posts. (you still have to vote 🙂 )
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
cekuhnen
@Phil.E
From my experience the split command is great if there is nothing else that later might intersect because of the current habit to over extend.
I am also not a fan of the extend command as Fusion does not provide much control over it.
Thus I rather prefer building the surface as I want with TS and then trim where needed.
Idea is posted:
http://forums.autodesk.com/t5/ideastation-request-a-feature-or/overwrite-self-intersection-warning-w...
Claas Kuhnen
Phil.E
Thanks for posting the idea. I hope that the workflow you want can be done eventually.
There is a way to get more control over splitting bodies that I had forgotten to try with this model yesterday. If you sketch the line used as a splitting tool there is a lot more control over it. Just wanted to show another solution to splitting since we are talking about it.
undefined
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
cekuhnen
This is all true but ideally the splitting command adds more geometry than needed.
Look this is better and cleaner:
pre create an additional surface to trim the bottle and make handle shorter
in my case I decided to make the cutting tunnel also bigger so I can blend surface without the need of a fillet later (2 in one task)
cut the shape open
loft blend the two openings
done - no other geometry changes nice and clean
undefined
Claas Kuhnen
TrippyLighting
As a learning exercise I've created my own object to see if I could replicate the steps discussed here. While that does work I find it's still quite a hack!
By far the easiest solution would be to allow a T-Spline to simply convert with some self intersection. I'd like for Fusion 360 to be a program that by default assumes a certain intelligence and expertise of the user.
I'd much rather explain it from this perspective to a new user and warn of the traps and dangers involved than being limited in this way, despite the fact that a conversion would still create a valid, self intersecting surface. Unless of course there is some algorithmic or math at play that does not allow that.
undefined
jeff_strater
An update on this topic: we discussed a solution to this problem that would do what you want. Not promising a date, but there is a solution that would tolerate the intersection
Jeff
Jeff Strater
cekuhnen
Hey that great! Thanks for considering this
Claas Kuhnen
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
