Edit the horizontal and vertical resultant angles of pressure network fittings
The horizontal and vertical resultant angles of a pressure pipe fitting can be seen in the fittings properties dialog box.  Currently they are greyed out and can not be edited like I can edit the insertion elevation.  I would like to be able to edit these values from the properties box vs having to do it in model space where it is very hard to be as precise as sometime I need to be.
See attached image of the data that I would like to be free to edit.
@swalz @philip.rotheyFDGN9
2 Comments
Thanks @Drea_Mueller for documenting your request on additional functionality to Civil 3D that you highlighted during our call earlier this week. Adding @Dino.Lustri and @almas.suljevic in for visibility.
TimYarris
Thank you for your idea. The development team will review the idea while customers continue to add feedback and vote on it.
Rail Community
