AutoCAD: length command with Shift key to substract length.
Hi.
In "Trim" command we can extend or cut if we press the key "Shift".
However if we are using the "Length" command (parameter: Increment (delta)), Shift key is not available so we can type -0.50 meters or 0.50 meters if we want to add or reduce the length.
If would be interesting that "Length"--Increase  would be compatible with "Shift" key.
Thanks.
1 Comment
TimYarris
Thank you for your idea. This would need to be addressed in core AutoCAD, but we will share this with the AutoCAD team for review while customers continue to add feedback and vote on it.
Answer Day
Rail Community
