Civil 3D Forum
Structures at end of vertex of polyline PipeNetworks
4 REPLIES 4
aj519
454 Views, 4 Replies
A structure was created at each polyline vertex within Pipe Networks Civil 3d.  How do I change this default setting for a created pipe network?
Thanks.
4 REPLIES 4
in reply to: aj519
I have the same question, this worked back in 2008 or 2009, when converting a polyline with vertices it would come in as one pipe with vertices.  Now using Civil 3D 2014, there is a structure inserted at each vertex.  We have a lot of curved pipes saved in GIS that are drawn as polylines with many straight segments, so this is a very important feature to us.
Nick Birth, PE
Hydraulic Engineering Section
San Francisco Public Works
City and County of San Francisco
Jeff_M
@Anonymous, Nick, I just opened up an old laptop for the first time in years. It still has C3D2008 installed so tried to duplicate what you describe and see no way of creating a single pipe with multiple vertices. Perhaps you used a tool to convert the segmented pline to one with radii prior to converting to a pipe network? I don't recall a pipe being anything other than one with start and end points, and a radius for a curved pipe.
Jeff_M, also a frequent Swamper
in reply to: Jeff_M
Hi Jeff, thanks for checking, it turns out I had done as you suggested and used a curved pipe.  It was so long ago I had convinced myself I did it the other way!
Rail Community
