Civil 3D Forum
Importing KMZ files into AutoCAD Civil 3D 2013
14 REPLIES 14
Message 1 of 15
mramseur
15804 Views, 14 Replies
Can I import KMZ files into AutoCAD Civil 3D R.2013, or do I need to purchase an add-on package that will make it work?  Does it work with just AutoCAD Map 3D?
If not, how do you import KMZ files into AutoCAd Civil 3D?
Thank you.
14 REPLIES 14
Message 2 of 15
TerryDotson
in reply to: mramseur
If you do consider an add-on, take a look at MapWorks Base which will import KML and a lot more.  We have a 21-day evaluation so you can see how it works for you.
Message 3 of 15
antoniovinci
You can also convert KML => DXF by means of the free Qgis, sir.
Message 4 of 15
neilyj666
although this should be a standard option ootb
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 5 of 15
Murph_Map
Don't know if it works in 2013 but its free. http://www.sl-king.com/fdokml/fdokml.html
Murph
Supporting the troops daily.
Message 6 of 15
antoniovinci
in reply to: Murph_Map
Thx, Murph: the FDO2FDO stand-alone tool allows a brilliant bidirectional conversion SDF <=> GIS.
As far as you know, does a SDF free viewer exist?  I've googled half an hour, without success.
Message 7 of 15
Murph_Map
in reply to: antoniovinci
Not that I'm aware of, I know a lot  of people on the Open Source sites have been wanting one but so far nothing out there that I know of.
Murph
Message 8 of 15
tcorey
SDF Draw is a free SDF Viewer:
http://www.furix.com/products/sdfdraw
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 9 of 15
Murph_Map
in reply to: tcorey
Tim,
I can't get that to open any of my SDF from the Samples folders. Have you used it?
Tim
Murph
Message 10 of 15
Murph_Map
Maybe this is why?
From that site:
  • Autodesk Mapguide SDF Component Toolkit must be installed
    It comes with Autodesk MapGuide
Murph
Message 11 of 15
antoniovinci
in reply to: tcorey
Well done, Tim, but it works only under the 2 following conditions:
  1. as noticed by Murph, you gotta install this small free plugin:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2525719&linkID=9242099
  2. SDFdraw supports the SDF/SIF pair created by the _MAP2SDF command, while FDO2FDO generates an incompatible SDF3 version (single file)
I attached a little example of what I'm talkin' about...
Message 12 of 15
tcorey
That's good info. Thanks,
Tim
Tim Corey
Redding, CA
Message 13 of 15
Hi, antoniovinci.
Imported KMZ file into Qgis.
Coordinate system - WGS84.
KMZ file has Latitude\Longitude degrees format.
I view point's coordinate in Latitude\Longitude degrees format in coordinate bar into Qgis.
After Export DXF instead of, for example, 26°47'S I have 26.7833 (meter).
What did I wrong?
Thanks!
Message 14 of 15
antoniovinci
d.kraynov wrote:
What did I wrong?
Nothing, sir: 26°47' is the DDMMSS format of the decimal 26.783333333333335 lat/long number.
Upon exporting to DXF, you surely forgot to declare the output CRS, e.g. an UTM one.
Message 15 of 15
I didn't find were I must set output CRS.
Rail Community
