COORDINATE SYSTEM UNITED KINGDOM U.K
Grover_Puma
Grover_Puma
Very good to everyone, I am looking for georeferencing and I can't find any suggestions for this area?
I want to know UTM and coordinate system to use
ACEPTA LA SOLUCION que responde a tu pregunta, esto ayudará a otros a encontrar respuestas de una manera mas sencilla.
Si te gusta esta publicación, dale ME GUSTA.
Saludos!
Accepted solutions (3)
Replies (17)
rl_jackson
There's quite a few, I've seen OSBG here quite a few times.
Rick Jackson
Survey CAD Technician VI
Pointdump
Hi Grover,
In addition to Rick's excellent advice, you can find UTM's >>>Here<<<.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Grover_Puma
very good but how do I get to that picture you show?
Saludos!
Grover_Puma
I have seen the page, however I could use wgs 84 as world and then London zone 30 U but for example Spain has
So I would like to know which of these options is for the United Kingdom zone 30 U
Saludos!
Grover_Puma
This occurred to me but I'm not sure it's right.
Saludos!
Pointdump
Grover,
Use command MAPCSASSIGN or MAPCSLIBRARY to search for coordinate systems.
Dave
Dave Stoll
Las Vegas, Nevada
Grover_Puma
BEP
COORDINATE SYSTEM UK NATIONAL GRID
ALTITUDE ALL LEVELS ARE TO BE TO ORDNANCE DATUM NEWLYN THE CHART DATUM IS 3.90 m below ordnance datum (newlyn)
Saludos!
Pointdump
Hi Grover,
More details please on what you're trying to do.
Dave
Dave Stoll
Las Vegas, Nevada
Grover_Puma
https://www.ordnancesurvey.co.uk/blog/ostn15-new-geoid-britain#:~:text=Britain's%20coordinate%20syst...
Saludos!
Grover_Puma
BEP
I am trying to put in the 3d civil that coordinate system that responds to the project site
Saludos!
Pointdump
Grover,
"Ordnance Datum (Newlyn)"
Civil 3D cares nothing about vertical coordinate systems or geoids.
I don't understand what you're trying to do. What data do you have? What are you trying to design?
Dave
Dave Stoll
Las Vegas, Nevada
Grover_Puma
Civil 3D doesn't care about vertical coordinate systems or geoids.
that´s good data
The only thing I'm trying to discover is the coordinate system that works in the United Kingdom and specifically the image that I show at the beginning of this thread, this to know a little more about coordinate system and how civil 3D works
for example, what happens if I place wgs84 and put zone 30 NORTH
It's the same as putting Ordnance Datum (Newlyn) to Civil 3D, is it the same to put one or the other? or what difference in accuracy is there? etc
Saludos!
Pointdump
Grover,
"coordinate system that works in the United Kingdom"
There are several that you can use to good effect. UTM84-30N covers most of UK. There's no "perfect" coordinate system. Most of the time your choice will be based on what your client wants.
There's really no way to set a vertical datum in Civil 3D.
Dave
Dave Stoll
Las Vegas, Nevada
Grover_Puma
solution
Saludos!
Grover_Puma
Thank you for the answers it has helped me a lot
Saludos!
Grover_Puma
Thank you
Saludos!
neilyj666
OSGB 1936 is the one to use
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Type a product name
