Announcements
Update project attribute definition in Bim360
Chandika_Jain6CPF6
Chandika_Jain6CPF6
Need to update the BIM360 Project attribute definition like if it is array type then update the array values.
share the end point(solution).
ashtamahima28
Community Visitor
Community Visitor
No, you can't filter the projects by version. Autodesk is keeping that close to the chest. You can't even find out what version a file is via the forge API. The only way to know is the process you're using. open Revit and see what shows up in that version https://19216801.onl/ https://routerlogin.uno/ .
