Announcements
Remove user from project B360 API
dk941
dk941
Hello!
We are looking into API's related to BIM 360
Is it possible to remove user from project using API  BIM360 ?
Thanks!
Littlerubarb
Looking at the Api documentation there is no method to remove a users from a project. The best you can do is change there role to one that has no access, which I sure it not what your looking for. Also under Account you can sent them to inactive, but again that probably won't help you.
The Quit answer is to delete a user or remove them from a project you have to login using the portal. No API function Yet.
Here are the reference links:
Projects Users: https://forge.autodesk.com/en/docs/bim360/v1/reference/http/projects-project_id-users-user_id-PATCH/
Account Users: https://forge.autodesk.com/en/docs/bim360/v1/reference/http/users-:user_id-PATCH/
The ability to remove users from projects using the API is a requirement for us.
We are building a automatic provisioning function and to be able to remove users from projects is very important.
Is this functionality on the list of API improvements?
Charlie_Portelli_PHZAJ8NNHFJA
Any updates on this topic? It would be extremely helpful for us to manage the removing of folks from a bim360 project via the API
