AutoCAD Forum
AutoCAD 2017 Service Pack 1 warning
10 REPLIES 10
Message 1 of 11
JTBWorld
1070 Views, 10 Replies
This service pack breaks the loading of certain AutoCAD apps that are using the plug-in auto loader mechanism (among others used by apps in the Autodesk App Store). If you notice that some commands are not available, typically from the Add-ins Ribbon tab you can uninstall SP1 if already installed to restore functionality and then wait for a fix from Autodesk. via my blog
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Tags (1)
10 REPLIES 10
Message 2 of 11
in reply to: JTBWorld
Hi Jimmy
do you know if this happened also in the Beta of the SP1?
Message 3 of 11
All my simple auto load LISP programs are not affected.
Ron
Message 4 of 11
JTBWorld
Peter, I can't tell outside of the Autodesk Feedback Community. Check in the Community forum.
Jimmy Bergmark
Message 5 of 11
JTBWorld
Ron, are you using the .bundle packages in the ApplicationPlugins folders to load? If not, then it should be no problem.
Jimmy Bergmark
Message 6 of 11
rkmcswain
Correct. They shouldn't be.
Message 7 of 11
rkmcswain
@JTBWorld - A swamp user reports it isn't broken. Could there be some variables at play here?
https://www.theswamp.org/index.php?topic=51778.msg568296#msg568296
Message 8 of 11
rkmcswain
in reply to: rkmcswain
Update to that post. It seems that this does not affect C3D, but AutoCAD only.
More Info: https://www.theswamp.org/index.php?topic=51778.msg568333#msg568333
Message 9 of 11
JTBWorld
A workaround is to remove the SeriesMax entry from the PackageContents.xml. For example: xmlSeriesMax="R21.0".
Jimmy Bergmark
Message 10 of 11
JTBWorld
I've got a hotfix prereleased from Autodesk: AutoCAD 2017 App Autoloader Hotfix
Jimmy Bergmark
Message 11 of 11
JTBWorld
It will only affect verticals after their respective SP1 is installed. This is what I found after installing AutoCAD Architecture 2017 SP1.
Jimmy Bergmark
Autodesk Customer Advisory Groups
