Announcements
edit edge of grading area
Hi all,
need advice.. i need to calculate volume for sandkey to existing seabed
first image is my grading plan in civil using grade to surface slope 2:1
but in reality the edge of grading not possible during construction in deep sea (for reclamation project)
any advice how I can make grading with each corner like my third pic?
thanks
damayanti
joantopo
Yes, civil 3D doesn't have this setting but PoweInroads has in the gradings.
I recommend adding this post in IdeaStstion because nobody has already done.
http://forums.autodesk.com/t5/autocad-civil-3d-ideastation/idb-p/31/tab/most-recent
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
Pointdump
NR,
Can you post your drawing? I have an idea, but I'd like to see if it works first.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Neilw_05
I think I understand your problem. What you are wanting is mitered corners in your grading. Civil 3D gradings cannot model mitered corners. You will have to manually draw in the corners with featurelines. You can use the gradings as a guide to lay out the geometry for the corners.
If you have access to C3D 2017 you can now use corridors from featurelines and the corridors will now automatcially clean up mitered corners. See the video provided in help system under new features for grading with corridors.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
joantopo
Clean up is just for fiexed width, in this case is not valid for daylight with surface target.
Enviado de Samsung Mobile
autoMick
To elaborate on Neil's response...
Use your existing grading to determine what your total footprint is.
Now draw a rectangle/polygon around the footprint (i.e. with square corners) and use that to grade back up to your fill elevation. During the grading process when you converting the rectangle to a featureline, you will be able to assign the elevations of the rectangle edges from the existing surface. Use a reasonable spacing of intermediate points to make sure the rectanglar feature line hugs the surface well (if needed). Note that the top of the grading won't be a nice rectangle. So....
Alternatively (the way I'd do it - and very similar to your right hand image)
1. draw the top rectangular boundary and assign its elevation
2. draw the bottom rectangular boundary, convert to a featureline and assign elevation from the existing surface as described above.
3. draw connecting 3dpolylines between the upper and lower rectangles for each corner (snapping to the elevations of those corners)
4. Add all these objects to a surface as breaklines
5. Swap edges on some of the surface triangles at the corners to get a consistent result if required.
See screencast below
Cheers
- Mick
Civil3d user in Australia since 2012.
Thanks @Neilw_05 .I tried to upgrade my civil 3d but in website the set up file still showing 2016 version>> Autodesk_AutoCAD_Civil_3D_2016_Win_64bit_WI_en-us_Setup_webinstall.exe
is the same set up for the 2017 version?
I'm wondering to try grading to corridor..
Thanks @autoMick i would try following your steps. And the video really help ^^
Thanks all for your help
Damayanti
