Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Where's the OSL node in MtoA?
3 REPLIES 3
Addis_Kidan
963 Views, 3 Replies
Been trying to locate the OSL node inside Maya but couldn't find it anywhere.
It's documented in the node reference manual here https://support.solidangle.com/display/A5NodeRef/osl
Maya 2018.2, MtoA 2.1.0.3, MacOS 10.13.
Thanks!
Tags (3)
Labels (3)
3 REPLIES 3
zenop
in reply to: Addis_Kidan
This node is hidden by default - if you go to your mtoa.mtd file, you can see the following:
[node osl]
	desc                    STRING  "OSL-based shader"
	maya.name               STRING  "aiOslShader"
	maya.id                 INT     0x00115D56
maya.classification STRING "shader/surface" maya.hide BOOL true
Set maya.hide to false to unhide it. I'm not sure why it's hidden - maybe it's for a good reason.
Addis_Kidan
Thanks so much @Zeno Pelgrims I That did the trick.
On another note, really miss shaders.xyz
zenop
Off-topic but hey ho - It'll be back soon. Just had to get another project released first, it took up all my time.
