Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Unable to edit/replace/delete texture files.
3 REPLIES 3
1731 Views, 3 Replies
Hi guys,
While my lookdev rendering stage, i do some necessary changes on textures and try to overwrite the old texture file.
It doesn't work, says that file is being used by application, however my Arnold Render View is closed, but maya opened.
Each time i had to update my textures, i close maya, replace the texture, make tx again, then reopen maya.
Its a long process, Is there anyway to skip this process. Really it eats my time alot.
Labels (3)
3 REPLIES 3
If you need to modify texture while you are rendering,Use the "Flush Caches->All" command.
in reply to: 863165618
thank you very much. This works.
Just made an account to say thanks!
