Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Stucco shader (Arnold 5, Maya 2018) with concrete and moss (displacement only on moss)
3 REPLIES 3
997 Views, 3 Replies
I want to create a concrete shader with some moss areas. The moss should then be displaced with a displacement map. The stucco works fine for me in that case, but I can't figure out how to add the displacement map that only affects the moss (and not the concrete). Maybe you can help, would really appreciate it!
P
Labels (3)
3 REPLIES 3
zenop
You'll need to build the same masking you have in your regular network into your displacement network.
in reply to: zenop
thank you!
Hi, I´m having the same problem, although I figure out to solve the issue, really silly way to handle displacements, I guess is how maya shading works but still really stupid way to mask two times, in the case to build a huge displacement graph node, how we can prepare the displacements to have different scale values for each displcament?, thanks
@Zeno Pelgrims
Technology Administrators
