Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Slow Viewport with MtoA
4 REPLIES 4
1169 Views, 4 Replies
Hey,
I noticed that my Maya Viewport 2.0 is getting very slow when I have the Arnold Renderview open. As soon as I start rendering, It gets slow (which is normal). When I stop the rendering, moving in Viewport 2.0 is still very slow. When I close the Renderview and reopen it, movement is back to normal. The issue reoccurs once I hit render and stop again across all my scenes. The only workaround right know is to constantly close the Renderview. Currently I am working with Maya 2018 and fresh installed MtoA 3.1.2.1 and the Viewport 2.0 settings are default. I have a Ryzen 2700X and 32GB RAM in my computer.. so machinewise everything should work?!
Does anyone know why this is happening and how I can stop Maya from becoming slow?
Cheers,
Kyan
Tags (2)
Labels (2)
4 REPLIES 4
Stephen.Blair
Did you try leaving more threads free?
  • Render Settings > System
  • Clear the Autodetect Threads checkbox
  • In the Threads box, enter a negative number to set the number of free threads (eg -4 to leave 4 threads free)
// Stephen Blair
// Arnold Renderer Support
Thank You @Stephen Blair for replying so fast! That tip helped a lot.
Is there a way of setting a thread number (e.g. -1) as a default when I start Maya? Its probably good to turn it to "auto" when I do a batch render but for LookDev purposes -1 is pretty good.
T0M0X
You can use Presets in Render Settings.
Then use Set Preferred Render Settings - User - <YourExportedSettings>
in reply to: T0M0X
Yeah, thats a good tip too. Never thought of that. Thank You.
Technology Administrators
