Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Skydome light alpha control
5 REPLIES 5
joie
446 Views, 5 Replies
Hi there,
This simple question is not apparently so easy to answer.
I need my HDRI dome light to appear in the RGB channels, but should be black in the alpha channel.
The "camera" visibility attribute doesn't do the job, since it forces the light to appear black, I don't want that.
I thought of the shuffle node, but the dome light doesn't have any alpha input, so I'm stucked with this.
Any way to do it?
Thanks in advance.
Tags (2)
Labels (2)
5 REPLIES 5
joie
in reply to: joie
Is this something impossible to achieve I assume?
Stephen.Blair
in reply to: joie
Not with skydome light. If it's visible to the camera, then the alpha is white.
// Stephen Blair
// Arnold Renderer Support
joie
in reply to: joie
May you suggest another workaround for that issue?
madsd
in reply to: joie
Show us with an image what you want to achieve.
The final output, if it's a screen dump from Photoshop, fine.
It is not clear to me what kind of output you want, but I am fairly sure we can cook up a solution for it.
Might be a combination of a couple of AOVs, or not.
joie
in reply to: madsd
No need for an example image in my opinion, just want to be able to control the alpha of the skydome light. I want to see it in the beauty render and be blak in the alpha channel. Just that.
Technology Administrators
