Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Simple decal or layered shader?
4 REPLIES 4
2358 Views, 4 Replies
Trying to create a decal effect similar to using a layered shader in Maya and having difficulties. The effect I'm looking for is a paper label (distressed, old) on a shiny bottle. So need, essentially, two different surface qualities on the same object. Any suggestions or related tutorials would be much appreciated. Using a Maya's Layered Shader doesn't seem to be working with the AiStandardSurface shader...
Jay
Tags (2)
Labels (2)
4 REPLIES 4
ben.fischler
Perhaps the Mix shader does what you're looking for? https://support.solidangle.com/display/A5AFMUG/Mix+Shader
I think you’re right Ben... tried the AiMix just after posting and am finally getting something close to what I’m looking for. Having some odd behavior when I turn off texture tiling (image turns into a black hole) but I’m sure I’ll get that straightened out. Thanks for the suggestion!
lee_griggs
There is also the Coat on the Standard Surface shader which can be used to layer a texture on top. Although the Mix shader is probably just as easy.
Lee Griggs
Arnold rendering specialist
AUTODESK
Thanks Lee. Will work with that as well.
