Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
saving as a TIFF
4 REPLIES 4
black.abbath
1386 Views, 4 Replies
saving as a TIFF
is there a way to add a sane file saving method when saving render as .tiff from Arnold Renderview? currently it always saving as a .jpg no matter if i adding extension to file's name or not.
(yeah, i know that can be get from [project_dir/images]/tmp).
also it would be very nice if you can make possibility to get transparency without AiSkyDomeLight set visibility - camera to 0.
all of above currently looks like shamanism and dances with tambourines, so i'm asking for UI to be more friendly to user.
thanks.
Tags (1)
Labels (1)
4 REPLIES 4
You mean File > Save Image ?
I just saved example.tif from the Arnold Render View, and it's a tif.
// Stephen Blair
// Arnold Renderer Support
black.abbath
in reply to: black.abbath
@Stephen Blair can you please tell me how to change file type while saving with Arnold Renderview so i could get TIFF? because i got only jpegs.
here are screenshots of arnold' settings and result (also tried to add extension manually - doesn't work either.)
when i changing "Image format" to tif, png or exr, it saving renders as jpg in any case :((((
  1. In the Arnold Render View, click File > Save Image
  2. In the File Name box, give the output file a .tif extension
  3. You get a tiff file
// Stephen Blair
omg, it finally worked!
my mistake was giving output extension .tiff instead .tif
thank you very much!!!!
Technology Administrators
