Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Region renders broken in MtoA 5.0.0.2 ?
6 REPLIES 6
427 Views, 6 Replies
Hi all,
We've just rolled out mtoa 5.0.0.2 and it appears the region rendering is broken. Values on the following attrs...
  • defaultArnoldRenderOptions.regionMinX
  • defaultArnoldRenderOptions.regionMaxX
  • defaultArnoldRenderOptions.regionMinY
  • defaultArnoldRenderOptions.regionMaxY
...seemingly have no effect on the render, interactive or batch.
But... I can't find anyone else complaining about this which seems odd. Can anyone confirm this?
Tags (1)
Labels (1)
6 REPLIES 6
Stephen.Blair
Right, looks like those settings are not exported.
How are you setting them? With a script or do you load defaultArnoldRenderOptions into the Attribute Editor?
As a workaround, you could set it the User Options
region_min_x 100 region_max_x 200 region_min_y 150 region_max_y 450
// Stephen Blair
// Arnold Renderer Support
I was setting the attributes via a script.
Tried the user options and it worked perfectly. Thanks Stephen!
jusbla
I'm seeing this when setting the properties via a script but using the user options isn't really an option, are there different commands we should be using?
Stephen.Blair
in reply to: jusbla
You can set the user options with a script too
// Stephen Blair
@Justin AWSThinkbox We saw issues with jigsaw renders today - tiles rendering whole frames which I guess must be down to this issue.
In case it's useful for anyone, there's a simple fix for this. Deploy the following as a pre-render script:
def setUserOptions():
    minX = cmds.getAttr('defaultArnoldRenderOptions.regionMinX')
    maxX = cmds.getAttr('defaultArnoldRenderOptions.regionMaxX')
    minY = cmds.getAttr('defaultArnoldRenderOptions.regionMinY')
    maxY = cmds.getAttr('defaultArnoldRenderOptions.regionMaxY')
    userOptions = 'region_min_x '+str(minX)+' region_max_x '+str(maxX)+' region_min_y '+str(minY)+' region_max_y '+str(maxY)
    cmds.setAttr('defaultArnoldRenderOptions.aiUserOptions', userOptions, type='string')
