Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Optix deNoiser and Arnold Noice -why two options?
2 REPLIES 2
2269 Views, 2 Replies
Hey there, just wondering why there are two additions that do a similar job? Is it a case of slight differences in quality and leaving it up to the user? or what are the key differences, is it just that Noice can be run externally and as a post-process? Is it to do with GPU utilisation?
Thanks!
Tags (2)
Labels (2)
2 REPLIES 2
Stephen.Blair
They are two completely different options.
Optix uses the GPU and is suitable for IPR and look dev. You wouldn't use the Optix denoiser for animation.
Noice is a CPU-based denoiser that can be used for final frames. Noice is higher quality denoising that takes longer. Noice can denoise animation sequences.
// Stephen Blair
// Arnold Renderer Support
Ah ok got it, so the Noice, avoids jumps in the solution, frame to frame in animation. Thanks a lot.
