Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Noice - what does this mean?
5 REPLIES 5
askinner6CDVL
1834 Views, 5 Replies
When I try and run noice from the utilities menu I get this error.
noice 5.4.0.1 [197d4d5e] - the Arnold denoiser Using 16 threads. Loading images... Loading file */denoise/test.exr". Required metadata not found, check that the image was rendered directly with Arnold.
I'm rendering everything I think I need to N,Z,diffuse_albedo,RGBA. And have Merge AOVS on and the frame range set to single frame (I only want one image). What is the metadata it's on about here? Is there a way to find out?
cheers - Aten.
Tags (1)
Labels (1)
5 REPLIES 5
lee_griggs
in reply to: askinner6CDVL
Did you enable 'Output Denoising AOVs'? How are you saving the image?
Lee Griggs
Arnold rendering specialist
AUTODESK
@Lee Griggs Yep, that's enabled. I was rendering in the render window and once it had finished, just doing save multi-layer exr. But the noice wasn't working on that and gave me that error.
However I just tried doing a straight batch render and running it on that output and it has worked!
So is there something about saving it directly out the render window that's saving it wrong?
lee_griggs
Yes, you should only use batch render/render sequence.
Lee Griggs
AUTODESK
Ok that's good to know, you live and learn!
Cheers for replying. Love your work btw 🙂
lee_griggs
Thanks Aten!
Lee Griggs
AUTODESK
